In VDJ v: 8.2 where have the custom buttons and knobs gone to in 4 deck mode please?
geposted Sat 15 Oct 16 @ 8:14 pm
There isn't room for them on the default 4 deck skin you could make a pad page linked to your custom buttons, the dial I'm unsure of a fix.
geposted Sat 15 Oct 16 @ 9:09 pm
Looks like i will have to stay with V 8.1 then unless there is a version 8.1 skin anywhere ?
geposted Sun 16 Oct 16 @ 1:18 pm
extract the v8.1 skin (bottom right of interface tab) rename the zip and you can use that with 8.2
What exactly is so vital on your custom dials? [like I said buttons can be added to a pad page]
geposted Sun 16 Oct 16 @ 1:40 pm
The ver 8.1 skin is available here.. https://virtualdj.com/documents/Skins/VirtualDJ%208.zip
https://virtualdj.com/wiki/SkinSDK8.html
No Pads support though in that skin.
Starting from 8.2 the default skin is "internal" and you can download and extract from Settings->Interface tab if you select the "Default" skin from the top of the list
geposted Sun 16 Oct 16 @ 2:03 pm
That's Sorted it Thank you very much DJ Dad :)
geposted Tue 18 Oct 16 @ 5:38 pm
..........and locodog
geposted Tue 18 Oct 16 @ 7:16 pm
