a while ago i saw for dl for a batch for to run b4 using vdj. it basically shutdown uneeded services. can anyone point me to it. im on 8.1 now and have 71 services. which isnt bad
geposted Sun 16 Oct 16 @ 10:03 am
https://virtualdj.com/addons/16006/VirtualDJ_PC_Optimizer.html
This is only for Vista & 7 though.
geposted Sun 16 Oct 16 @ 11:32 am
I have my own batch file that shuts down no needed services, no need to download software, but you need to know wich (only those that use to much memory) can be closed.
ill write an exemple here if you want and how to do it.
geposted Mon 17 Oct 16 @ 1:11 pm
What os and yes please show us an example.
Thanks
Thanks
geposted Mon 17 Oct 16 @ 3:23 pm
im using windows 10. the new builds have many more services. i have been using a program for years called "cacheman" its a tweak program. and you can pick a template ie gamer, power use, low battery. the new version has one for daw/musicians. which is supposedly to help latency and shut down services you dont need . i dont have a printer. so why have that service running. i went from 111 services to 70. and its a fully operational pc. blackviper.com has info too. now a while back someone clowned my about worrying about services. well, use ccleaner and remove crap and uninstall windows things you dont want. like sports, netflix, crap like that. and you will see a difference.
geposted Thu 27 Oct 16 @ 6:19 pm
