Hello everyone,
I use a hercules dj control mp3 as a second controller. Now I would like to map the "autobeat" button so that the LED is lit as long as the pitch is 0.00%. As soon as the pitch value rises or falls above or below 0%, the LED will no longer light up.
The following functions are mapped to the key:
Key "autobeat" pitch_zero.
LED_AUTOBEAT pitch_zero? on : off
The desired function is not executed.
What mapping commands do I have to enter into the lines?
For your help, I thank everyone in advance.
greeting
Martin
greeting
Martin
geposted Sun 16 Oct 16 @ 2:51 pm
You're missing a space between "pitch_zero" and the question mark.
geposted Sun 16 Oct 16 @ 3:47 pm
Thank you locodog.
Now it works.
Now it works.
geposted Sun 16 Oct 16 @ 4:41 pm
