I was checking my playlists and I noticed that some fields were changed. No problem yet. I left clicked to change the desired fields I wanted added or subtracted. When I was done my playlist track order changed. To make this explanation as simple as possible I will use color for track order. My original order was green, white, red, green etc. Now they are grouped by a-z or year etc. The odd thing is when I add the playlists to side list or automix they are in the original order. My question is how do I change the playlist back to the original order?
geposted Sun 16 Oct 16 @ 8:10 pm
if you right click the headers I believe u can select reset sort on there
geposted Sun 16 Oct 16 @ 8:18 pm
Are your headers in the same order; artist, title, bpm, etc. in your browser, as they are in when you made your play list?
geposted Sun 16 Oct 16 @ 8:20 pm
Thanks, that worked. I did not see that option.
geposted Sun 16 Oct 16 @ 8:40 pm
I must have changed that order when I was resizing my columns. I am using a laptop with a touch pad and sometimes my old clumbsy fingers hit the wrong thing or two things at once!!
geposted Sun 16 Oct 16 @ 8:42 pm
