I bought a licence specifically so I didn't have to deal with the ads popping up and they're still there. please help
geposted Thu 20 Oct 16 @ 10:44 pm
Make sure that you are logged into VirtualDJ and you can see the License under the config.
geposted Fri 21 Oct 16 @ 2:25 am
From what I can see is that you bought a controller licence.
Do you own the corresponding controller to your licence and is the controller connected and on?
If not, I believe it will not "activate" the controller licence version while starting VDJ. Meaning it would still be the Home version which will show you some ads.
geposted Fri 21 Oct 16 @ 10:05 am
As long as you are logged in it knows that you have a license regardless of the controller being connected or not.
geposted Fri 21 Oct 16 @ 11:14 am
