Topic: Pioneer sx2 dvs set up.
I just got an sx2 and want to use my turntables with it. I have used my denon mk2 in the past and it was simple audio configuration hit the mk2 icon then the timecode icon and it was set. When doing this,with the sx2 only time code 1 appears I then added time code 2 and went to calibration. My left deck showed up I'm both the left and right calibration box. Can anyone one tell me how to configure the audio.
geposted Wed 26 Oct 16 @ 9:58 pm
I appreciate the help. I checked out what you advised but still having issues. As stated vdj is recognizing my sx2. It works fine as a stand alone controller. But im wanting to use it with my two tt's. When I hit the timecode button in audio configuration only time code one pops up in the input this is different when using for instance my mk2 where both timecode 1 and 2 show up in the input section . So I add timecode two and have tried every combination of channel options. When I go to the calibration page both a left and right box shows up but my left turntable puts a signal in both the left and right box when the crossfader is left and the right shows a signal in both boxes when fader is to the right. I'm so confused I've never had a simple configuration issue like this before.
there's a hack to make this work
took this from another post use with caution I think it requires you to have Serato installed
open: regedit.exe
go to: Computer\HKEY_CURRENT_USER\Software\Serato\SeratoDJ
change the value of "dvs_plugin_enabled" from "0" to "1"
open Serato DJ -> then the driver will be updated to 2IN2OUT Mode
Now you can run 2 decks with Timecode in VDJ8 with the Pioneer DDJ-SX2
More informations about this and a little Video:
http://deejay-basics.de/2014/11/pioneer-ddj-sx2-dvs-soundkarte-aktivieren/
I just got an sx2 and was working a party with virtual DJ..an hour in my midi locked and my sound went up.. luckily I was able to use one of the decks and get through the event. Do I have to configure something. Tried restarting and mid became locked after several minutes. Should I only be using Serato?
Thanks!
This thread is about turntables. Are You using turntables? Did you read this whole thread and look at the links I provided?
Back ti the trail,i bought this console,but how can I use it with timecode ,,any help please.
Any update? seems that the dvs plugin key is missing in my registry...
Sorry to bump this. Im trying to get the SX2 to work with timecode and failing miserably. Serato took away Free DVS so no option in the registry anymore. any ideas?
Hello i have a ddj sx2 and Im trying to use it with my tables in vdj8, I followed the steps to enable, but in the registry there is no DVS enabled plugin, I have serato installed but does that mean I need to have the DVS in serato enabled?
djdad wrote :
No need of any regustry hack.
Have a look here https://virtualdj.com/manuals/hardware/pioneer/ddjsx2/advanced.html
You will need a Pro license though
This doesn't work either. In the newest version of Virtual DJ I don't see the Pads option anywhere.
Is there anyone out there who can help me get this working?
Thanks for the help.
custom button this
set "@$sx2_dvs" 1 & reinit_controller 'DDJSX2' 2000ms
locodog wrote :
custom button this
Thanks, will try and keep you up to date.
locodog wrote :
custom button this
It works for the 2IN/2OUT configuration but the sound of the DVS record is still playing instead of the sound of the mp3. Also I don't see the special Two Soundcards at the top in the settings.
By the way, I want to use vinyl timecode, could that be the problem?
Never Mind, I found the problem. I had to add an extra line to support the phone input in my mapping.
I want to thank you for the help, you got me on the right track.
