Hey Everyone, this is probably really simple but I can't figure it out.
I would like to play a Halloween video clip from the sampler with no audio while a song is playing. Thanks and keep up the great work,I'm loving version 8.2
geposted Fri 28 Oct 16 @ 2:03 am
Put the Video into a Sampler slot.(drag n drop)
Open it with the Sampler Editor (CTRL+Click on the Sample)
Set the Sample to Audio only (disable the Video Option)
Close and Save
Trigger the Sample
Other Options...
- You can use the Slideshow Video Effect and put the video into a folder.
- You can assign a custom knob or a knob on your controller as .. sampler_volume_master and set that to 0% (minimum)
Close and Save
Trigger the Sample
Other Options...
geposted Fri 28 Oct 16 @ 2:28 am
Thank You Sir!
geposted Fri 28 Oct 16 @ 9:21 pm
