GUYZ!!! i'm a beginner so i need help ...as i'm not able to afford a real dj set ..m doing all the things with keyboard and mouse only....thats where the problem lies ..i need the key-mappings for all the shortcuts...THANKS IN ADVANCE!!!A BIG HELP I WANT...
((P.S-NOT ONLY FOR 114 shortcuts which is basic but also which is used frequently in mixing))
geposted Fri 28 Oct 16 @ 8:03 am
There's too many to list and it really depends on how you have laid out your mappings
I've had many keyboard mappings over the years, some that included eq adjustment some didn't
here's 2 that always make it into my keyboard mappings
deck 1 level up, but if level 100% drop level to 0%
Opposite, level down but if level = 0% jump to 100%
Also keyboard only users can benefit from turning on windows filter keys, there's a tutorial blog about it on my homepage
repeat 1ms & deck 1 level 100% ? deck 1 level 0% : deck 1 level +3.33%
repeat 1ms & deck 1 level 0% ? deck 1 level 100% : deck 1 level -3.33%
geposted Fri 28 Oct 16 @ 8:24 am
