Forum: VirtualDJ Skins
Topic: Edit Default 8.2 Skin - Page: 2
OK this is what i copied from a skin when I had someone do it for me on the default 8.0 skin...
Will this work??
<group name="clock" x="190" y="8">
<!-- <visual>
<pos x="+0" y="+0"/>
<size width="56" height="22"/>
<off x="371" y="1481"/>
</visual> -->
<textzone>
<pos x="+1" y="+1"/>
<size width="100" height="30"/>
<tooltip>CLOCK\n Click to toggle between 24hour clock and am/pm</tooltip>
<text size="30" color="#aaaaaa" weight="bold" align="left" format="%hour12"/>
<text2 size="30" color="#aaaaaa" weight="bold" align="left" format="%fullhour"/>
<text3 size="30" color="#aaaaaa" weight="bold" align="left" format="%counter"/>
</textzone>
</group>
OK ...
I managed to get the clock bigger and make the rings on the skin blink when song is ending.
If anyone can help me on changing the default 4 deck skin to black and changing FILTER to FX and HEADPHON to PHONES and a visual on the screen to know whether vinyl mode was on and slip mode was on.. like a dot and VINYL under it for example.
Thanks!!
headphone is on line 6227
filter to fx I don't understand, you want to just change the text?
change to black, I think that is just the background at the top of the png file
dot I'm not sure
Yes, just change text.
Since I have the SZ it is used for filter and other effects.
This controls the filter text,
<textzone><text action="filter_label"/></textzone>
check the how headphone is formatted and do similar.
What am I changing?
Also in TextEdit on Mac, how do you find the line???
It's up you to figure it out,
you've been told which bit is currently, the formatting for headphone is similar to what you want
As for display line numbers, I don't know, have you tried "google"
http://uk.lmgtfy.com/?q=textedit+line+numbers
I changed HEADPHONES to PHONES and I'm still getting the error again.
This is what I get for line 6227
</button>
headphone is found in only 2 sections of the 4 deck xml, the one you want isn't on the master panel.
you know that
text="headphone"
search for that
Like I said, I tried that and I am getting an error.
I am getting impossible to open skin.
Your zip folder tree should look like this
*.zip
>>files
if you've gone like this you get the error
*.zip
>>folder
>>>>files
So how do I avoid the folder. I have the folder on one of them and it works. Can you log in to my computer and see what I'm doing wrong?
The error you are getting means that your xml file is not parsing properly, so there is a XML syntax mistake.
Use a XML Editor or Notepad++ (Google it) to help you spot the error.
e.g. could be a tag that doesnt close properly
I was zipping the entire folder rather than just what was in the folder.
As far as changing HEADPHON to PHONES I tried on my Mac and got the error regardless. I tried doing it on a pc and it worked when i changed HEADPHON to PHONES. Not sure why it says HEADPHON on the actual skin when it actually says HEADPHONES in the script.
I am still trying to figure out making the default skin black and a visual on the screen to know whether vinyl mode was on and slip mode was on.. like a dot and VINYL under it for example
Instead of saying filter on each channel on the main panel to say FX.
I tried changing filter to FX with no luck.
TextEdit on Mac has been known to break XML - I've seen it change the quotes, so that instead of "" it has “”.
You can see it here:
DJ Koz wrote :
<text size=“20” color="##00ff00" align="center" weight="bold" action="get_clock 24"/>
Look at the quotes around the size="20" - they aren't correct.
Should be:
<text size="20" color="##00ff00" align="center" weight="bold" action="get_clock 24"/>
Use a different editor as suggested above, or be extremely careful :)
Thanks SBDJ.
I was wondering what the problem was.
It could have avoided this whole thread if i didn't use TextEdit.
As far as the skin itself, I am trying to make it all black and would like a way visually (i know the dot is there... but i have to stare at it to see if it's on or off) for VINYL and SLIP.
Also wondering why there is no VU meter for Master on the Default Mac skin.
There will be, but your controller doesn't use master, therefore you don't need it.
98%
