Okay - I'm sure I'm just overlooking this...
I'd like to be able to sync the master tempo between two decks on demand.
e.g. I manually sync the tempos, then during the mix, as I speed deck 2 up, I want deck 1 to follow to get song on deck 2 up to the proper tempo.
Maybe assign this feature to a custom button for each deck.
geposted Sat 29 Oct 16 @ 3:01 am
Hey Tommy.
I think you should try to use pitchlock on a custombutton like this.
geposted Sat 29 Oct 16 @ 6:07 am
It's also possible to do this in options menu, search for "pitchLock"
geposted Sat 29 Oct 16 @ 10:02 am
That worked perfectly. Thank you!
geposted Sun 20 Nov 16 @ 2:54 am
