Previously when loading a song onto either deck from sidelist/or automix, it would
remove it almost right away.
Now it only removes after about 1/2 way through the song.
This is on build 3343. It works fine on the backup.
In previous versions there was a way to set the amount of time to remove.
Any suggestions how to get it remove sooner?
geposted Mon 31 Oct 16 @ 7:51 pm
It depends on the historyDelay setting which also marks the song as played.
geposted Mon 31 Oct 16 @ 9:02 pm
First, you need to check the HIstoryDelay setting (by default its 45 - in seconds). After the time defined in that setting, the track is considered played.
For Sideview, you have the setting removePlayedfromSidelist. If its set to Yes, tracks will be removed instantly once they get the played flag, which is the case here.
Similar option for Automix. If the setting AutomixautoRemovedPlayed is set to always, the tracks should be removed when getting the played flag, but there is a chance (not sure - will have to check) this happening once the next track is loaded.
geposted Mon 31 Oct 16 @ 9:06 pm
It's removed on next load
geposted Mon 31 Oct 16 @ 9:33 pm
Yep it was history delay. For some reason it changed.
Since I did not change settings, I never thought to check that.
Also noticed when connecting the VMS5 it only shows config 1
in the audio settings. Previously it showed VMS5. Doesn't seem
to effect anything, don't why these settings changed.
Thanks
Thanks
geposted Tue 01 Nov 16 @ 1:30 pm
