I just got.the JBL prx715's. Did some research and asked many DJS. These were recommended by several trusted sources. I took them out for the first time Saturday. I was simply amazed at how they sounded. Loud, a ton of low end, and power to spare.
Oops first post here in a while. I may have overwritten someone else's post. If so, I am so sorry
Rick
Rick
geposted Mon 31 Oct 16 @ 8:39 pm
Why are you considering 15" top cabs if you're going to be using 15" bins?
Hooking everything up so it's running 3 way, it's not really necessary (and even detrimental) to have a 15" driver as basically a midrange unit.
It would be better to couple the bins with 12" or 10" top cabs. It should give you a better midrange sound and also look nicer with smaller cabs over bigger bins.
geposted Mon 31 Oct 16 @ 9:25 pm
Where in the uk are you? If near[ish] Leeds Manchester, I might be interested in in your old gear.
geposted Mon 31 Oct 16 @ 9:28 pm
thanks grooving dj that sounds a better way will look in to it thanks
geposted Mon 31 Oct 16 @ 9:34 pm
On the other hand, you may not need the subs sometime and can just bring the 2 way. Something to thing about.
Another point is, I thing you are downgrading going from Mackie to Atlo. Is there a particular reason you are looking at Alto?
geposted Mon 31 Oct 16 @ 9:53 pm
its just that i have lost faith in the mackies there is no particular reason that im looking at the atlo im open to other suggestions my budget is a bit tight at the moment £2000 thanks
geposted Mon 31 Oct 16 @ 9:58 pm
Have you looked at any of the line array stuff? RCF has some nice units. Will pick this up later, time to go to work.
geposted Mon 31 Oct 16 @ 10:07 pm
I think RCF would be a struggle with just £2000.
You might manage to put a dB Technologies system together for that though. A pair of Sub05D and a pair of Cromo 12s perhaps would be around £1500. Swap the Cromos with Opera 12s and you'd still be under £2000.
geposted Mon 31 Oct 16 @ 10:15 pm
thanks
geposted Mon 31 Oct 16 @ 10:17 pm
