in menu prelisten - options there is an "item start at 50%". Its not possible to deaktivate this here.
in menu info options is the same item whitch could be used correct.
geposted Sat 05 Nov 16 @ 12:55 pm
Treat title mismatch: prelietsen = prelisten
geposted Sat 05 Nov 16 @ 3:49 pm
You should be able to use the action... setting 'prelistenStartPos' 'value' but just tried and doesnt work. Will report to Dev Team.
geposted Sun 06 Nov 16 @ 3:04 am
Try
setting 'prelistenStartPos' 0.5
geposted Wed 23 Nov 16 @ 7:21 pm
use your mouse and do a right click at the start of the prelisten bar..
geposted Wed 23 Nov 16 @ 7:41 pm
