Does anybody have any idea of how to map a sound effect to a controller button?
Example: Echo to a particular controller button, reverb to a different controller button - not just map one controller button to toggle the selected sound effect.
geposted Sat 05 Nov 16 @ 9:42 pm
Take a look at this page
https://virtualdj.com/wiki/VDJScript%20Examples%20Database.html
geposted Sat 05 Nov 16 @ 10:19 pm
Hi there, which controller are you using?
Please check this thread: https://virtualdj.com/forums/213667/Hardware_Technical_Support/Re-Mapping_part_of_Behringer_CMD_DV-1.html
I hope to issue a re-hashed control map for the Behringer CMD DV-1 soon, it can handle 3 FX slots per deck (4 actually, but l am going to keep 1 slot per deck in reserve for video FX and video transition FX respectively), with up to 6 parameters per FX. I'll announce it on that thread when it's done (if ever).
You should then be able to take over the Action codes ("scripts") and use them on your own controller.
geposted Sun 06 Nov 16 @ 12:05 am
I'm using Virtual DJ 8.2 v3471
Controller: Hercules RMX
Thanks peeps. I will try these tips.
geposted Sun 06 Nov 16 @ 5:20 am
effect_active 'echo'
Edit
Or include the slot, in this example slot 2
effect_active 2 'echo'
Edit
geposted Sun 06 Nov 16 @ 2:04 pm
Thanks all for replying.
Locodog - that worked wonders.
I appreciate it.
I appreciate it.
geposted Mon 07 Nov 16 @ 6:01 am
While I am old school when in comes to djing I am trying out with the behringer cmd series set up of 2 pl , 1 mm as controller and 1 dv for effects . Is there anyone here successfully mapping this set up as a stand alone set up? I wonder where audio out put goes out and how to monitor cued tracks apart from the laptop
geposted Sat 15 Apr 17 @ 1:30 pm
;-) pongan nuevos plugins
geposted Sat 15 Apr 17 @ 3:54 pm
This is an English on forum, please try our Spanish forum here, thank you.
geposted Mon 17 Apr 17 @ 4:16 am
