hi, does anybody know if you can have the keychange on a slider or any easier way than the rotary knob. vdj 8 is much easier with the tabs but its always crashing so ive switched back to 7.thank you!
geposted Tue 08 Nov 16 @ 3:26 pm
try either of these two
param_add -0.5 & param_multiply 2 & key_move
param_add -0.5 & param_multiply 2 & key_smooth
geposted Tue 08 Nov 16 @ 3:51 pm
