I was testing out the New update for the weekN & now my jog wheel has a delay/pause when releasing/scratching & I didn't change the the jog wheel setting
geposted Thu 10 Nov 16 @ 11:33 pm
https://youtu.be/Nd244kueTys delay picking up
geposted Fri 11 Nov 16 @ 7:21 am
So, the delay is when the jog is released ?
Tr y to set the setting touchWheelSpinThreshold to a lower value , like 0.5 or even lower.
Also check what you have for the rampScratchTime setting. Start with the default value 0.1 and try to go lower.
geposted Sat 12 Nov 16 @ 9:21 am
but it been ok after setting from 8.0 so I need to redo my jog after new updates ?
geposted Sat 12 Nov 16 @ 3:47 pm
IIRC touchWheelSpinThreshold was not present in 8.0
touchWheelSpinThreshold default value is 0.8 while in your picture above, it shows 0.9, so most likely it was manually set that way and not by some update
btw, did you try with a lower value ? Did the delay got improved ?
geposted Mon 14 Nov 16 @ 2:29 am
every time i try to set up 8;2 after a few minutes playing there are pops inthe sound and athen after a few seconds he shuts down, keep on playing, but the controller doesn't work anymore, and also the mousse and keyboard acting weird, this is since the update to 8.2? WHAT MUST I DO
geposted Tue 22 Nov 16 @ 10:54 am
Any Effects running at that moment ? Any AudioOnlyVisualizations ?
Were you playing Karaoke/Video files at that moment ?
geposted Tue 22 Nov 16 @ 4:30 pm
