Hi
I would like to upgrade my home setup with a Novation Launchpad Mini. I'm currently using the pioneer XDJ-RX. But how can I use these at the same time? Do I need an extra mixer or is it possible without?
Thanks
Thanks
geposted Fri 11 Nov 16 @ 2:13 pm
if you are using VDJ on laptop then just plug the launchpad in and use it as well as your controller. The launchpad doesn't store any files, it just triggers whatever you want in the software, no sound comes out of it.
geposted Fri 11 Nov 16 @ 2:23 pm
