Greetings. I want to index my MP4s and MP3s so they are grouped together in the browser. On left side and top of the column, I click on the grey box (which has no micro help) and there seems no way to group properly. It's a mix of MP3 & MP4. Multiple clicks re-index, but I see no logical order. Would you be kind enough to fix this. Thanks.
geposted Sun 13 Nov 16 @ 9:59 am
Right-click the column header to select which headers are shown, and select filetype, then you can click that to sort by filetype.
geposted Sun 13 Nov 16 @ 10:16 am
Thanks Adion. That is a good workaround. It adds another column. I would rather see the left column work as any other when you click the top and it indexes properly.
geposted Tue 15 Nov 16 @ 12:24 am
It does, but it doesn't sort by filetype, it's a smart sort that takes several fields into account
geposted Tue 15 Nov 16 @ 4:27 am
