I only recently started using version 8, but I am desperately in need of some help with Automix.
I used to be able to run automix in "remove silence" mode, and it would learn after moving the automix points once to skip intro skits/outro skits on certain songs.
Now I need to do it every time in automix editor...
I can not use one of the other automix types, as I play songs from note to note, usually.
Any help would be appreciated.
geposted Sun 20 Nov 16 @ 2:58 am
and the POI editor is not my friend here
geposted Sun 20 Nov 16 @ 3:13 am
Not getting your problem, but,
Try use the automix pad pages, it might help.
geposted Sun 20 Nov 16 @ 3:29 am
Problem is, most times I want to skip only silence, but occasionally I want to skip an intro or outro. I can't train the automix to skip intro/outro on demand, which is something I used to be able to do in version 7
geposted Sun 20 Nov 16 @ 3:51 am
With poi editor you can move the silence points of individual tracks.
The automix editor on the other hand only saves mixes between pairs of songs, so will only apply again the mix if the same 2 songs are mixed in the same order
geposted Sun 20 Nov 16 @ 5:07 am
which point do I edit to make this happen?
geposted Thu 24 Nov 16 @ 2:07 am
Mix Full
geposted Thu 24 Nov 16 @ 2:28 am
