Hey Guys,
I am still using VDJ 7, just because that is what I am comfortable with. I have instilled 8, and just have not put the time in, to get comfortable on it yet. Same goes for helper, which uses one of my computers. I have a full paid version, but have moved on several times to new computers. I uninstalled VDJ from the old computers before getting rid of them. How come it keeps showing that my VDJ on my current computers are the Home Free Version, rather than Full Pro? I have signed in with them as well. Any help would be great. Thanks.
geposted Sun 20 Nov 16 @ 6:25 pm
7 - > requires serial find it here -> https://virtualdj.com/users/edit.html - my licenses tab
8 -> requires login
8 -> requires login
geposted Sun 20 Nov 16 @ 7:17 pm
With VDJ 7, if it's saying it's the Home version then you've downloaded the Home version. :-)
You need to download the Pro version from your account, then enter the serial number.
With VDJ 8 the versions are all within the one file. The version that runs depends on your login.
If you have a Pro VDJ 7 license then when you log into 8 it will enable the pro version.
geposted Sun 20 Nov 16 @ 7:30 pm
Also, you can only be logged into two computers at a time. If you try to log into a third computer, it will log out of one of the others.
geposted Sun 20 Nov 16 @ 8:46 pm
Hey, thanks guys. I got it. I was downloading 7 from the sites download area, verses through My Accounts License area. I also decided to install 8, and learning my way around it today. I need to get onboard at some point. I DJ, plus play Videos and Karaoke, throughout a night, so I was just nervous to make the transition.
geposted Sun 20 Nov 16 @ 9:50 pm
