I may be being a bit thick here.....I have downloaded the EQ10 and it comes up with a box that says it has installed.....All ok so far.....
Where is it? I can't seem to find it anywhere.....
geposted Tue 22 Nov 16 @ 7:21 pm
You need to either apply it as an effect to a deck or the master output.
geposted Tue 22 Nov 16 @ 7:22 pm
To carry forward my lack of understanding......How do I do that?
Sorry to appear a bit thick.
geposted Tue 22 Nov 16 @ 8:19 pm
Have you read the manual?
geposted Tue 22 Nov 16 @ 9:13 pm
The online manual doesn't explain how to assign a master effect.
Go to the master tab, click down the effect box until you find the desired effect then click on it to activate.
geposted Tue 22 Nov 16 @ 9:18 pm
I got it!
Thanks for the explanation :-)
geposted Tue 22 Nov 16 @ 9:41 pm
