I try to use this option (flag on yes), but when i turn down the volume to zero, track don't stop....still going on. Any suggestions?
geposted Thu 24 Nov 16 @ 2:44 pm
i can't make it work either.. maybe i don't understand how it functions but i am pretty sure i do
latest early build
latest early build
geposted Thu 24 Nov 16 @ 2:45 pm
No I try is not working with Crossfader ...It's strange there is another option Faderstart....If you flag this one YES.....when you put to zero the volume track stop...if you put volume to max....track start.....with fader Start/Stop.....nothing happen
geposted Thu 24 Nov 16 @ 2:51 pm
sounds like a redundant setting then
geposted Thu 24 Nov 16 @ 4:43 pm
Indeed, FaderStartStop is an additional mode of the FaderStart setting to stop the deck when the Volume Faders reach minimum position, so it requires FaderStart enabled. Is there a case when someone would want just the the Fader to Stop the track when down without starting when up ?
geposted Thu 24 Nov 16 @ 5:05 pm
