Does anyone know how to correct this issue when using automix, songs are jumping up and down in pitch. They are fine when not enabling automix, however when using automix songs are jumping up and down in pitch. I can actually see by the wave pattern where it's going to happen. I played a few songs with this happening and I had to reset those particular songs because when loaded normally it remembered the crazy jump in pitch point.
geposted Thu 24 Nov 16 @ 3:32 pm
in the automix editor have you got the "match bpm" option ticked?
geposted Thu 24 Nov 16 @ 3:36 pm
Or take a look in the Automix-Options and set "autoMixBeatMatchOnFade" to No.
geposted Thu 24 Nov 16 @ 4:17 pm
