Browser Tweaks is an application to help you easily configure the Browser of a VirtualDJ skin.
You can change any of the colors of the Browser, choose between default and Alternative icons (found on many custom skins) or even add Browser to a floating window
Download Link : https://virtualdj.com/plugins/?addonid=80491
Notes :
- Windows only
-Once installed, the exe will be located to ProgramFiles->Browser Tweaks folder (EDIT: The new Installer adds a Desktop Icon too)
- If you choose to add a floating Browser window, assign a keyboard or custom button as show_window 'browserfloat'
Notes :
- Windows only
geposted Fri 25 Nov 16 @ 2:55 pm
very nice thanks
btw the install doesn't make a start icon anywhere i can find on windows.
geposted Fri 25 Nov 16 @ 3:07 pm
Yeah i know, need to find a better Installer application :)
For now, you can go to ProgramFilesx86->Browser Tweaks and create a desktop shortcut of the exe file
geposted Fri 25 Nov 16 @ 3:16 pm
fantastic work here DJDad.
Please could you consider adding options to adjust the text sizes and maybe a font selector too??
geposted Sat 26 Nov 16 @ 3:17 am
Changed the installer and now it should offer you the option to add a Desktop shortcut.
@Mark, Just the Browser font ?
geposted Sat 26 Nov 16 @ 3:45 am
How does this cope with skins that have multiple browsers (i.e. if the browser has various sizes due to other skin parts being switched in/out)?
Has this been considered? Does it only work on the main browser, or all that it finds?
geposted Sat 26 Nov 16 @ 7:42 pm
The tweaks apply to every single browser element inside the zip file
geposted Sat 26 Nov 16 @ 11:03 pm
thank you so much Dj dad :-) certain browsers i like using have like 15 <browser> settings i have to change.....but not with this all in one tool....im trying out & editing more skins :-)
geposted Sun 27 Nov 16 @ 12:46 am
Updated to 1.1
- Added option to change the Browser Fonts (name,size,weight)
geposted Mon 28 Nov 16 @ 3:43 am
Browser Tweaks is updated to version 2.0
Changelog
Download Link: https://virtualdj.com/plugins/?addonid=80491
PS. It's becoming more a Skin Tweaks ;)
Changelog
- Ability to include Custom Icons from another skin
- Ability to include floating Windows from another skin
- Ability to change global Font and adjust the overal size
- Ability to adjust the height of the Browser Lines
- Added Plugin GUI Browser Font selection
- Minor fixes
geposted Fri 21 Jul 17 @ 12:28 pm
Man I Luv this app...its made my life so much easier modding different skins... Thank u so much
geposted Fri 21 Jul 17 @ 12:47 pm
On my PC (Windows 7 with 1920x1080 screen) some things in the app don't display correctly.
I have marked the affected areas:
Also, seperator should say separator
geposted Fri 21 Jul 17 @ 1:09 pm
Will have a look. What is your screen's DPI ? It should be in Display Settings , the one that says something like "size of text 100% (Recommended) "
geposted Fri 21 Jul 17 @ 1:46 pm
Yes it looks like that was the cause. It was on 110% and if I set it to 100% there's no problem.
However, shouldn't your software be able to deal with that by itself? People could be using all sorts of % in their Windows settings.
geposted Fri 21 Jul 17 @ 3:17 pm
Want to change the color as indicated in the diagram. What is that called scrollbar background or button?
geposted Fri 21 Jul 17 @ 3:55 pm
Selected, and Focus (2 elements)
In your screenshot focus is currently on Songs list and Selected is on Folders list (just to understand the difference)
geposted Fri 21 Jul 17 @ 4:31 pm
groovindj wrote :
Its in my Todo List - to offer High DPI support - but not a high priority atm....shouldn't your software be able to deal with that by itself?
Speaking of ToDo List, i am working on 2 features that will be included in version 3..
- A Preview window with some kind of mini/demo Browser to see how the Color changes affect the view, without having to know what each one is doing and without having to export to a skin and see in VirtualDJ.
- Load/Save/Edit Profiles so that you can save your favorite options/colors and easily apply to any skin you wish to edit.
geposted Sat 22 Jul 17 @ 12:23 am
It's starting to sound like the "wish" I posted recently...
groovindj wrote :
"it would be nice to have this ability (changing browser colours) from within the VDJ executable, so it would be applied to every skin as your choice - only over ridden if a skin specifically has the <color> statement.
As the browser is already drawn by the exe and isn't a skin graphic, it makes sense to set its colours from the exe too."
geposted Sat 22 Jul 17 @ 7:23 am
Browser Tweaks is updated to version 3
Changelog
Hopefully i didnt miss anything :)
Download link
Changelog
- Added new Browser tabs to tweak the FX GUI, Search and Prelisten
- Added new option for White Icons (for White Browsers)
- Added Browser Preview
- Black & White application themes
- Added Custom Profile management (load/save/delete)
- Default (Dark) and White Browser Profiles included
- Added Tooltips (and option to disable)
- Theme and Tooltips settings saved
- About Help window to check for updates and Browser Tweaks forums
- Minor fixes
- Possible High-DPI fix
Download link
geposted Thu 03 Aug 17 @ 2:57 pm
The issue I had before with the text at 110% zoom is (almost) gone. Thanks for fixing it!
There's just one small problem remaining...
geposted Thu 03 Aug 17 @ 3:07 pm
