Second night with this version my deck 2 froze totally when I loaded a vdj edit file. Deck 1 was playing normal but half my buttons on my controller (MC6000mk2) were not responding. Couldn't even load another song. I could though clone deck 2 from deck 1. Weirdest issue I've seen so far. I am finishing the night with 3471.
Will investigate to see if it was a corrupt file... I was online when it happened.
W10 i7 16GB RAM 3GB Nvidia
geposted Sat 26 Nov 16 @ 3:53 am
Can you reproduce with the same vdjedit?
geposted Sat 26 Nov 16 @ 7:37 am
i tried without controller plugged in and i couldn`t reproduce. I`ll try tonight with the controller plugged in. funny thing is that i loaded the same file back in b3496 and i had a crash back then. Here is the file:
https://www.dropbox.com/s/2osmcyt5v8wqs6c/Sunlight%20%28Extended%20Club%20Mix%29%20-%20The%20Magician%20Ft.%20Olly%20Alexander.vdjedit?dl=0
geposted Sat 26 Nov 16 @ 7:10 pm
Tried to reproduce with controller plugged in and couldn't make it freeze or crash with b3523
I had a similar issue with 3496. Don't know what has changed after 3471 but i have had 2 similar issues so far with while playing vdj edit files. My computer is super clean and get my video clips and songs from rekord pools.
geposted Sun 27 Nov 16 @ 2:35 am
Are you running video? If so this did this all the time for me with my MC3000. I finally started running a Windows 8.1 NVidia driver (347.81) and it fixed this issue.
geposted Mon 28 Nov 16 @ 8:22 pm
347 is a really old driver. I'm up to date with Nvidia. I dont think it has something to do with Nvidia.
geposted Mon 28 Nov 16 @ 9:17 pm
