Good afternoon guys,
I recently bought a new controller and I decided to try the VirtualDJ 8 (previously used other software) and it has convinced me, since the improvements regarding VirtualDJ 7 are quite good.
The fact is that when i load a song on a deck, it automatically positions the pitch to match the BPM with the song on the other deck. I would like to know how it can be disabled. I have the smart play disabled and also I have reset pitch on load enabled.
Thank you very much for your help.
geposted Sun 27 Nov 16 @ 5:44 pm
I just found the solution!
In Settings -> Audio I found the autoBPMmatch option, which I had not seen before.
Thank you for your attention and apologies.
geposted Sun 27 Nov 16 @ 5:50 pm
