Hi Everybody, i wanna know how to map this fonction with on a custom button.
i have a little issue when i use VDJ with the pioneer Djm s9. when i switch with an ohter Dj, when he is finish and want to switch back with me, i always have a deck which is disable. At the display I have two identical waveform on the 2 decks. The only way I have found to fix this problem is to go through the 4 decks display and go to activate the deck that was not. As I use another skin, I want to save time by customizing a button with this function for both decks.
I do not know if it's a bug because it seems to me that I did not have this issue before but I do not remember with which version
Can someone help please.
geposted Mon 28 Nov 16 @ 6:59 pm
