Hello,
Totally new to this forum, sorry if there's somewhere better to post this. I'm using VD 8.2 with a Numark Mixtrack. I've bought a license for the controller ($99) however after ten minutes I'm still getting the "you need to buy a license for this controller if you wish to continue" message. On the licenses page in the settings screen, I have two trials which have expired and then one for "Analog Mixer" which is still active, presumably the one I bought. Is this correct? If so why can I not use my decks after ten minutes? Should it read "Numark Mixtrack" instead of "Analog Mixer"?
Please help a very new DJ out, I'd really appreciate it, got a party this Friday I wanted to DJ at.
geposted Tue 29 Nov 16 @ 3:47 pm
Have you ever had a cracked copy of VDJ on your system? if so it will have screwed up your registry files. If not, your status on here says "controllerist" so your license is working, when you go into the license tab on VDJ does it show your controller license?
geposted Tue 29 Nov 16 @ 3:51 pm
Thanks for the quick reply, no I've only ever downloaded from the site, never tried a cracked version. Yeah it has the license but it just reads "Analog Mixer." I'll attach a photo.
geposted Tue 29 Nov 16 @ 3:57 pm
Sounds like you bought an analogue licence instead of one for your controller. Contact support and they will sort it for you.
https://virtualdj.com/contact/step2.html
geposted Tue 29 Nov 16 @ 4:01 pm
Much obliged, I thought that could be it. Purchased it in a hurry one night as people started arriving!
Cheers guys.
Cheers guys.
geposted Tue 29 Nov 16 @ 4:08 pm
