Hey everyone I have a video i was given by my client off her Iphone and if i play it outside of VDJ it plays fine when i load it into VDJ the video is turned side wards, is there a way to fix this
geposted Tue 29 Nov 16 @ 6:45 pm
I think the TellyVisual PLUS can do it.
Ask Don
http://www.tellyvisuals.com/
Ask Don
geposted Tue 29 Nov 16 @ 6:51 pm
TellyMedia should be able to play it with correct orientation.
geposted Tue 29 Nov 16 @ 9:26 pm
HI Guys i got the app but i am having a hell of a time getting the video to turn do either of you know how to work this
geposted Wed 30 Nov 16 @ 5:37 pm
Same as here.
I got an iphone video that I couldn't play ever because it is upside down. Reading this thread reminded of TM. So, I loaded it to TM's Media slot and, (viola!) perfect replay with correct orientation!
It works, man.
It works, man.
geposted Wed 30 Nov 16 @ 6:21 pm
Why not edit the file in other programs before playing in Vdj ?
You can use programs like, Sony Vegas, Adobe Premiere or Wondershare video converter etc..
geposted Wed 30 Nov 16 @ 6:31 pm
If you are playing it in TM and it does not rotate automatic then the video itself would have no indication that it is rotated. If you are still playing the video in VDJ then there is nothing TM can do about it realistically. Occasionally you run into a video that has no rotate information in it. If that was the case, then i could add a rotate for TM's video but would do it only for the plus version of TM.
geposted Wed 30 Nov 16 @ 9:17 pm
