Numark Mixtrack Platinum. Settings:
Master > Numark Mixtrack Platinum > chan 1&2
Headphones >Numark Mixtrack Platinum > chan 3 & 4
Now I have no sound in headphones on deck 1 and 2. I do have sound on headphones on deck 3 and 4. What settings do I need to get headphones on all four decks?
geposted Thu 01 Dec 16 @ 7:17 pm
geposted Fri 02 Dec 16 @ 5:13 am
Thanks for the reply. It didn't help. The problem is still the same.
geposted Wed 07 Dec 16 @ 7:26 pm
Sorry, reading your post again, it seems that you have prelistening issue on some of the decks.
I suppose you are using a 4 deck skin. To prelisten a deck, the relative PFL button needs to be turned on.
If you click on any of the PFL buttons on the 4 decks skin, does sound comes to Headphones ?
Keep in mind that since the Platinum is a 2 deck controller, if you want to properly control 4 decks with a 2 deck device, you need to assign some buttons to select the Left and the Right decks or use the LEFT/RIGHT buttons on the skin.
Each time a deck is assigned as Left or Right, the relative side of the controller will be assigned to control that Deck (including the PFLs)
geposted Wed 07 Dec 16 @ 7:46 pm
You let me to the solution! It were the settings. Above the PFL's are filter knobs which stood in a "left-side" as shown below. When in upright position, the headphones work. Thanks.
geposted Wed 07 Dec 16 @ 7:59 pm
Well, that would be the last thing i would ask you to take a look, since with the Filters engaged you wouldnt have proper sound on the Master as well and not just Headphones.
Anyways, glad you figured it out.
geposted Wed 07 Dec 16 @ 10:55 pm
Understandable, but I haven't hooked the controller up to speakers. So, the master wasn't checked yet.
Thanks for the help.
geposted Fri 09 Dec 16 @ 10:02 am
