Galaxy tab s2... 64 gig. The one you can put your sim card in it for DATA and phone calls lol.
One thing i noticed is the wave display, is a bit little bit laggy.
Should it be... it has a 1.8 GHz + 1.4 GHz octa processor.
3 gig of ram
And 64 gig of memory
3 gig of ram
geposted Fri 02 Dec 16 @ 10:38 am
I have the Tab S 8.4 and it's not the tablet, it's the wifi signal causing the problem..... and the VDJ remote app itself may contribute to the issue.
Assuming you're using it for VDJ remote of course ......
geposted Fri 02 Dec 16 @ 11:03 am
Yes, and can i save the ip address . When i entered it and closed vdj later on, i thought id get back into the app and i had to re enter the ip
geposted Sat 03 Dec 16 @ 8:07 am
