Hello community,
I use the Vestax VFX-1 controller in conjunction with virtualdj 8.2.
With the standard mapping, which is already stored in vdj 8.2, I get the LED's not to light up.
I guess it is somehow to the definition file.
In vdj 7 the same problem existed. This could be fixed with the Vestax VFX-1 Def & Mapper by cioce. The definition file caused the LEDs to light up again.
Under vdj8 I have not found such a definition file. Therefore, my request: Can you please help me to bring the LED's to light up.
Perhaps there is someone who can create such a definition file?
I thank you in advance.
greeting
Martin
greeting
Martin
geposted Tue 06 Dec 16 @ 6:38 pm
take the v7 def file found in devices and add the word "force" to the start of the file name.
I think that's all you'll need to do.
maybe options disableBuiltInDefinitions yes, but I don't think that is needed.
geposted Tue 06 Dec 16 @ 7:42 pm
Thank you Locodog,
Had just tried it. Unfortunately, no success.
Do you have any other ideas?
greeting
Martin
greeting
Martin
geposted Tue 06 Dec 16 @ 9:11 pm
Sorry typo on my part
prefix the def file name with [the dash is needed, I think]
force-
force-
geposted Tue 06 Dec 16 @ 10:37 pm
We ll have a look and let u know soon.
geposted Wed 07 Dec 16 @ 6:37 pm
Locodog,
Many heartfelt thanks for your quick help. I've tried it and it works. I am so glad that it now works. I have so often thought about how I get the LED's to light up and now it works finally.
Thank you so much.
Can you possibly explain to me why I must use the prefix "force-"?
Best regards
Martin
Thank you so much.
Best regards
Martin
geposted Thu 08 Dec 16 @ 5:15 pm
I believe the v8 definition files are built into the V8 executable and are the preferred ones.
If you want to use another definition file for a natively supported controller you have to "force" VDJ to use the custom one.
That is way you need this prefix in front of the filename.
geposted Fri 09 Dec 16 @ 3:45 pm
