Anyone using the Dell 22 (ST2240T) touchscreen? I've been researching out touchscreens and I was looking for one that will fit nicely onto the 19" dj rack.
The ST2240T screen is 21.5 diagonal (Glass from edge to edge, which is crucial - don't want any raised bezels)- 20.5" wide body. So it will overhang on the 19" rack slightly. I'll just Velcro strip the back where it meets the frame of the rack to hold it in place.
It's 1920 x 1080, so DJDADS "Multi-Touchscreen" skin will natively fit perfectly. It also has 10-point touch for the multitasker lol
Just thought i'd share this monitor with the group - looks like a great fit for this awesome Multi-touchscreen skin!
Which one are you using?
geposted Fri 09 Dec 16 @ 6:55 am
