Hi just bought a vms5 but for some reason can not get the mixer eq to work i can see the changes in the software but it makes no difference to the sound any ideas please ? i have the LE version that come with the controller.
geposted Mon 12 Dec 16 @ 9:14 am
Make sure its set to Pre-EQ mode
https://virtualdj.com/manuals/hardware/americanaudio/vms5/advanced/eqmode.html
geposted Mon 12 Dec 16 @ 4:35 pm
I had it set to PRE - EQ and tried POST -EQ but made no difference
sorted now i had to edit the mapping
geposted Mon 12 Dec 16 @ 4:37 pm
There are 2 ways to work with the EQ and the VMS5..
1 Have it at Pre-EQ mode and use the factory default mapping. In this case you will be using the Hardware Equalizer (the one that the unit offers).
2. Have it at Post-EQ mode and remove the fake_eq on action from the ONINIT key. In this case you will be using the VirtualDJ Internal Equalizer
geposted Mon 12 Dec 16 @ 4:41 pm
i had to edit the PRE -EQ as it just would not work for some reason a friend is a software programmer he did it in seconds all working now
geposted Mon 12 Dec 16 @ 6:35 pm
Hi mate im having same issues tried mapping any chance you can help me
geposted Tue 28 Mar 17 @ 8:32 pm
