Is this unit still a viable option (Vestax VCI-400)??
I know Vestax is no more but the unit itself was solid.
Thoughts and opinions please......
geposted Tue 13 Dec 16 @ 12:38 am
Faders, buttons and pots may be difficult to find exact replacements.
Pretty solidly built and capable. But lacks of rgb pads
geposted Tue 13 Dec 16 @ 12:49 am
Rgb as in colored pads?? If so that doesn't mean very much as my SP1 doesn't have them either.
Can this be used with timecodes when used with VDJ??
geposted Tue 13 Dec 16 @ 12:51 am
I believe so bro they released a firmware update that let you do that. Don't quote me on that but I believe that's correct. You will probably have to do your research to find the firmware download
geposted Tue 13 Dec 16 @ 2:44 am
My favorite travel controller :)
I've used mine both with SDJ and VDJ but not with timecode.
I did a little research before but didn't go deep enough. The VCI-400 EGE firmware (Ean Golden Edition) might be your best chance.
It's just hard to switch back and forth as far as I remember. The simple reason why I left mine on the default settings.
some articles:
http://forum.djtechtools.com/showthread.php?t=70163
http://djrankings.org/community/forum/category-12
some articles:
geposted Tue 13 Dec 16 @ 6:14 am
Yes!
https://techtools.zendesk.com/hc/en-us/articles/204940624-VCI-400SE-Firmware-Upgrade-Procedure
https://techtools.zendesk.com/hc/en-us/articles/204940684
https://sumfuruya.blogspot.it/2015/04/vestax-vci-400-firmware-download-macwin.html
geposted Tue 13 Dec 16 @ 9:54 am
