Hey VDJ,
At the Pioneer website I see they have setup a certified program for Dj software.
I don't see your name, while you support a bunch of there hardware :)
geposted Tue 13 Dec 16 @ 10:06 am
I think Yes , is it on the controller supported list in VirtualDJ's WIKI.
Hopefully this helps.
https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
best regards
best regards
geposted Tue 13 Dec 16 @ 2:59 pm
Virtual DJ may not be certified for the CDJ-2000NXS2 by Pioneer
But the CDJ-2000NXS2 is certified for Virtual DJ by Atomix (the makers of VDJ)
So the CDJ2000 NXS2 works with VDJ8 and is natively supported
geposted Tue 13 Dec 16 @ 7:21 pm
