@locoodg
"slip on & loop 0.5 & repeat 235ms & down ? key 0 ? key -1 : key -1 ? key -2 : key -2 ? key -3 : key -4 : loop 0 & key 0 & slip off"
Can you please modify this script (your script) so that as you press the button the key ends @ 7 o'clock and not 9 o'clock? If possible add more keys to scan past as it reaches 7 o clock?
Regards.
Regards.
geposted Thu 15 Dec 16 @ 6:23 pm
Use the keyloop effect, or there's enough info there for you to figure this one out for yourself.
geposted Thu 15 Dec 16 @ 6:40 pm
