Hi - I bought a Gemini G4V and am trying to install the virtual dj LE, however, as I download and open the program, it says the serial number I am providing is invalid /very frustrating, as I know it is not (as I am copying the # as it says on the disc provided with the controller). Any solutions or other dj programs I can use (already dislike virtual dj lol)
Des
Des
geposted Mon 19 Dec 16 @ 7:02 pm
If you bought this used, the serial number may have been registered by the previous owner. If that's the case, you will have to buy a new copy, as serial numbers are non-transferable. If you bought this unit from a dealer, it may have been a return, and the previous owner used the serial number, refer to my first option as it is the same. If you bought this from a reputable dealer, you will have to contact them, or try our support personal which is located here.
geposted Mon 19 Dec 16 @ 9:51 pm
i install alredy a virtual dj pro 7...
where i can find serial no. of vitual dj pro 7?
geposted Sat 29 Jun 19 @ 10:46 am
VDJ 7 is no longer available. You need to buy VDJ 8.
geposted Sat 29 Jun 19 @ 11:24 am
