I'm not sure if it is possible so I'm asking here instead of the wishes forum.
Is it possible to disable (global or per deck) set Action POIs?
Lately I had some tracks which are "good" at the start and the end but the middle part is to hard for an ordinary night. So I set up some APOI to skip the middle part. (Which works nice btw).
But in private or other occations I'd wish to be able to disable the POIs and listen to the track as is.
geposted Thu 22 Dec 16 @ 9:35 am
You could make edits with track cleaner or make your skip apoi conditional on a var
geposted Thu 22 Dec 16 @ 11:11 am
Track cleaner is a good idea. Totally forgot about that.
geposted Fri 23 Dec 16 @ 2:56 pm
