With the new skin Builder, I was wondering what designs people came up with?
geposted Thu 22 Dec 16 @ 5:39 pm
Mine's not finished yet (will probably get in there manually and adjust a few things) but it's basically two big track info displays at the top, then pads and FX under that, then browser.
No mixer or deck controls as that's all on my hardware.
The pads and FX are only on the skin for info, because the controller can't display what's on the pads or which effect is active. If it could, I would get rid of those too!
geposted Thu 22 Dec 16 @ 5:46 pm
Yea I did a minimal type skin also, added a daylight and incorporated Phantomdj prepare and automix views
I posted this the skin builder thread hopefully they wont hold it against me.
geposted Fri 23 Dec 16 @ 12:44 am
Would anybody know or has anybody tried to enlarge the drop down micro window that is there for the sampler?
geposted Fri 23 Dec 16 @ 1:04 am
