I used the quick key "Shift+Space" in version 7 to auto fade from one deck to the other. The option to change the speed at which the transition happened was a slider in Config called "Auto-Cross Length". Version 8 does not have this option and I need to know how to change the speed at which this transition happens. In controllers, it is "Alt+Space", which is mix_now_nosync. But it is too fast for what I need. Also, the length in the Automix playlists is not what I'm talking about or what I need. I just need to change this speed. Please Help!
geposted Fri 23 Dec 16 @ 4:58 pm
geposted Fri 23 Dec 16 @ 5:21 pm
Please do not post the same question twice, thank you.
LOCKED BY AMAHM
LOCKED BY AMAHM
geposted Sat 24 Dec 16 @ 8:23 am
