When I do a search.... quite often I'll have a few songs at the top (Maybe 2,3 or 4) and then a space before the remaining songs.
Also When I click to sort on a field.... They do their own sort and the remaining songs do a separate sort.
Does the separation have significance?.... or is it a bug?
geposted Fri 30 Dec 16 @ 3:51 am
The ones at the top are in your currently selected folder, and the ones below are the full search. Makes it easier for example if you have an eighties folder selected and you search "duran" it will show their tracks from the eighties at the top. If however you have a folder with all files selected it will return only one group of search results.
It's by design not a bug.
geposted Fri 30 Dec 16 @ 6:10 am
Thanks!
geposted Sat 31 Dec 16 @ 5:01 am
