I have changed the default mapper for my launchcontrol to control fx parameters
I cant get this to work on deck 2 -> deck 2 effect_slider 8
works fine on deck 1 -> deck 1 effect_slider 8
must be some kind of bug
this is controlling a vst fx before u ask why i need so many sliders :-)
thanks for any help
thanks for any help
geposted Sun 01 Jan 17 @ 6:47 pm
Odd that you haven't specified the fx name or slot number.
I think as you have it written it will be trying to manipulate whatever is on slot 1.
I've got turnado mapped to my launchpad, and with the fx name specified it works fine
Btw what vst?
Btw what vst?
geposted Sun 01 Jan 17 @ 9:05 pm
i am using turnado
it used to work fine but not any more mapped just the way it is
when i activate that knob it now acts as knob 1 for some reason
the way i use it is i activate the fx with a button then adjust it via the knobs
does it not default to slot 1 if you do not specify? .. i am always using it on slot 1
geposted Sun 01 Jan 17 @ 10:32 pm
never mind solved it forgot a " in my xml ugh.
geposted Sun 01 Jan 17 @ 10:53 pm
