My soundconfig is speaker only, internal soundcard.
Using the POI editor VDJ asks if the sound should go through master output, which is okay.
Now using the POI editor blasts your ears if you are using headphones.
I'm not able to control the volume. It is not the deck volume level that is currently in use (in my case only deck 1), nor does the POI editor use the master output level.
Any suggestions on how to reduce the level?
geposted Thu 05 Jan 17 @ 7:33 pm
Master vol dial is dropping it here...
geposted Thu 05 Jan 17 @ 8:58 pm
I should add:
Windows sound device volume is at 40%.
VDJ master is at 100%
and Deck 1 is at 50%.
But the POI is way louder than the deck.
geposted Thu 05 Jan 17 @ 8:59 pm
The poi player will be playing at saved gain, full gate.
Is you soundcard free from enhancements?
What sound config, just; master 1&2?
geposted Thu 05 Jan 17 @ 9:05 pm
It is.
Its just the built in realtec chip. nothing special
Nope. At leaste the focus skin's master vol does not drop the POI vol
geposted Thu 05 Jan 17 @ 10:15 pm
I tried default and fruits, both worked ???
geposted Thu 05 Jan 17 @ 10:19 pm
Omfg... How stupid am I?
The "master" volum slider I used to reduce the POI level was actually the headphone volume slider... XD
Please burry this thread somewhere deep down and never bring it up again.
Sorry for the confusion...
geposted Fri 06 Jan 17 @ 9:33 am
