so close to being able to mix BUT, i need my mic...
this is my problem:
i have my mic (samsun Co1u ) selected as an input on VDJ8 BUT it isnt picking up any audio... any clues as to why this may be?
the mic is plugged in to my pc directly btw with usb.
this is my problem:
geposted Fri 06 Jan 17 @ 1:00 am
the mic works fine in VDJ 7 btw but im not using VDJ 7 as it dosnt have what i need in VDJ8
geposted Fri 06 Jan 17 @ 1:36 pm
Are you hitting the mic on button on master panel of default skin?
geposted Fri 06 Jan 17 @ 1:50 pm
yeah. check these pics
Audio Settings : https://puu.sh/td5Gd/2db06b82b7.png
Mic Control: https://puu.sh/td5I2/253de36c5e.png
geposted Fri 06 Jan 17 @ 2:04 pm
most likely the issues is both are not the same sample rate set the master and mic to 44100 hz
geposted Fri 06 Jan 17 @ 10:26 pm
Does your Mic work properly (get any signal) in Windows Recording ?
geposted Fri 06 Jan 17 @ 10:38 pm
