I've got a pad page almost finished,
it clones the action deck to the deck above or below it, so deck 3 clones to deck 1 etc, and it clones eq & filter & volume
it also puts the clone in a loop [1/8 to 8]
On the shift pads I've got it doing stuff to the clone, so keyloop up keyloop down, loopOut [with fade & stop] loopOut [no fade just stop], stop source deck, volume cross link [the clones volume is inverse from the source deck and linked]
Part of the idea is that 2 deck users get a easy intro to 4 deck use, while only needing to use the 2 deck skin that they're used to.
But I've got two shift pads to fill, I could just add reverb to the clone or some other fx and with volume cross link you've a wet/dry, but any ideas from you guys would be good.
geposted Mon 09 Jan 17 @ 7:05 am
