for some unexplored reasons, refuse to run track player!
no matter in what kind of deck you load a track, click on the button to play, or space, or on the controller by pressing the play button, nothing happens!
after looking at the construction of a grid of bits can be seen that the track like a very short loop, twitches, but no sound.
but only when you click the mouse on the length of the wave in the track, the track begins to play.
WHAT'S HAPPENING??? the settings do not change anything and do not add
geposted Tue 10 Jan 17 @ 12:20 pm
It sounds like a wrong soundconfig.
Could you upload some screenshots of your current config?
geposted Tue 10 Jan 17 @ 1:01 pm
my sound cards all right.
problem in your program!
just I am talking to support, and they were asked to remove the file settings.xml
after which all came to life and to work, but without my custom settings ...
sound went all right.
I really still can not figure out is why there was such a problem ?!
can someone faced beneath?
geposted Tue 10 Jan 17 @ 1:09 pm
I'll record a video and send the link here to view
geposted Tue 10 Jan 17 @ 1:10 pm
Посмотрите
https://youtu.be/Oa2yBAlm5CM
geposted Tue 10 Jan 17 @ 1:31 pm
Is it only this track behaving like this ? Check the track with the POI Editor, there may be some actions assigned to Hotcues, jumping from one to the other.
geposted Tue 10 Jan 17 @ 4:42 pm
so are all the tracks on any deck, even new untested tracks behave this way ... sad ...
POI editor is working properly, hot cue, lines, loops and wiretapping it works, but in the decks (4 in all) does not want to. play immediately, it is possible only by clicking on the cue such as
geposted Tue 10 Jan 17 @ 5:12 pm
