Hi
I'm wanting to achieve the following...
1 button to cycle through "mixer", "Video", "Scratch", "Master" & "Sampler" views on the main mixer section.
1 button to cycle through "Sidelist", "Sampler", "Automix", "Karaoke" and other shortcuts on the Side View panel.
Can someone help with the scripting for this, or point me to a tutorial or example script that points me in the right direction?
Cheers,
k
Cheers,
k
geposted Thu 12 Jan 17 @ 6:11 am
skin_panel 'audiomixer' on ? skin_panel 'videomixer' on : skin_panel 'videomixer' on ? skin_panel 'scratchmixer' on : skin_panel 'scratchmixer' on ? skin_panel 'mastermixer' on : skin_panel 'mastermixer' on ? skin_panel 'audiomixer' on : nothing
Sampler? what skin are you using?
sideview 'sidelist' ? sideview 'sampler' : sideview 'sampler' ? sideview 'automix' : sideview 'automix' ? sideview 'karaoke' : sideview 'karaoke' ? sideview 'sidelist' : sideview 'sidelist'
geposted Thu 12 Jan 17 @ 6:32 am
For Sideview, you can use
sideview -1 (select previous view)
sideview +1 (select next view)
these actions are simpler than the ones locodog wrote above and include the Shortcuts (clones) as well
For panels, you need to know the names of the panels or even better the name of the "group"
For the default skins. the name of the group for the center panels is "mixer" , so you can use ..
skin_panelgroup 'mixer' +1 (select next panel)
skin_panelgroup 'mixer' -1 (select previous panel)
geposted Thu 12 Jan 17 @ 7:14 am
Thanks...
I'm using the GianB 4 deck skin... Where do I find the Panel/Group names in the XLM?
Appreciated!
Appreciated!
geposted Thu 12 Jan 17 @ 10:50 am
a bit different there, try this
cycle '@$center' 5
cycle '@$center' 5
geposted Thu 12 Jan 17 @ 11:44 am
Rocking.
Cheers!
Cheers!
geposted Fri 13 Jan 17 @ 1:40 am
