I like the simple 2 deck default skin for video work. But when a track is playing I cannot read the key on the deck, time and bpm are ok.
Can this be rectified?
geposted Fri 13 Jan 17 @ 2:19 am
You would have to edit the skin yourself or ask the creator of the skin of they could edit for you.
geposted Fri 13 Jan 17 @ 3:18 am
I suppose I could do that myself.
There again maybe not..the default skins are not in the skin folder, perhaps they can be downloaded or something?
geposted Fri 13 Jan 17 @ 3:21 am
Yes, when you choose the default skin. a download link in the bottom right of the screen will appear
geposted Fri 13 Jan 17 @ 3:49 am
to get a copy of default go to interface menu and look for the link at the bottom right
hang on, which skin default 2 deck show key
geposted Fri 13 Jan 17 @ 3:51 am
Thanks guys..I've got it.
geposted Fri 13 Jan 17 @ 4:00 am
there are other ways that reskinning, custom buttons and display the key by making the name `get_key` pads can do this too,
geposted Fri 13 Jan 17 @ 4:32 am
