Hi im using Virtual DJ 8 with my Numark Mixtrack Pro but no sound is coming out of the headphones even though I have downloaded the asio4all driver which you need for it all to work. Does anyone have any ideas what I need to do to get this to work?
geposted Sat 14 Jan 17 @ 12:35 am
Can you post a screenshot of the audio settings?
geposted Sat 14 Jan 17 @ 1:59 am
Which Mixtrack Pro? There are three generations.
Also you should not need ASIO4ALL. The Mixtracks are class compliant (meaning they're supported by the OS) and no driver is required.
By the way, ASIO4ALL only uses the OS driver anyway, by piggybacking on top of it. It's not a genuine driver itself, it's an emulator.
geposted Sat 14 Jan 17 @ 11:34 am
Is it the filter-setting on the Mixtrack itself? Are they "in the middle" ?
geposted Sat 14 Jan 17 @ 1:49 pm
I never recall needing ASIO4ALL when I had the Mixtrack Pro 1?
geposted Sat 14 Jan 17 @ 6:24 pm
I just bought Virtual dj with my numark mixtrack pro controller, but when i open virtual dj and plug in my controller it says i need a pro license when i bought it just know with the mixtrack pro included, what should i do? do i need to download somthing els or turn somthing on? it is connected through USB to my Mac.
geposted Sat 14 Jan 17 @ 10:50 pm
I'm sorry but your issue has nothing to do with the originator of this threads issue. Please do not hijack someone else's thread, but start your own. Thank you.
geposted Sat 14 Jan 17 @ 11:16 pm
